Activity › Forums › Adobe Encore DVD › error message
error message
Posted by John Culleton on June 21, 2007 at 12:11 pmi’m getting ‘DVD project title remote not set’ dvd seems to work ok so can i ignore this one?
John Culleton replied 19 years, 3 months ago 2 Members · 2 Replies -
Andy Brennan
June 21, 2007 at 7:05 pmIf it works, I guess don’t worry…
but I think I’ve had this before too…to fix it look at your Project Pane…there’s tabs for “project”, “menus”, “timelines”, and “disc”.
Once you select the “DISC” tab, the “properties” pane (for me, it’s on the top right of the screen) will change to the Entire DVD Disc’s properties. I believe the thing you were describing is under that “disc properties” tab. Play with those properties and see if it fixes it.
Does that help?
Andy. -
John Culleton
June 21, 2007 at 10:03 pmthx Andy, seems there was a missing link to ‘first play’, i thought that was automatic. oh well…
