Activity Forums Adobe After Effects error message
  • error message
    Posted by Paapoopa on January 4, 2006 at 6:52 am
    anyone encounter not enough ram to create image buffer?
    does that means I need more RAM?
    I am already running a 2GB RAM and have set my aftereffects settings to
    max memory usage 80%
    and max RAM cache size 30%
    and I have definatly more then enough disc space for my overflow volume.
    What else can I do?
    Paapoopa replied 20 years, 8 months ago 3 Members · 3 Replies
  • John Dickinson
    January 4, 2006 at 9:30 am
    Are you working with really large images? This sometimes happens to me when I have very large Photoshop files. Try changing Maximum RAM usage to 120% and Maximum Ram Cache size to 60% and see if that helps.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Steve Roberts
    January 4, 2006 at 1:08 pm
    If this happens when rendering, you can clear the RAM cache every so often by accessing the Scret Prefs. Hold down shift when accessing the prefs from the top menu — don’t release shift until the dialog box comes up. Try setting it to “purge every 5 frames during Make Movie”.
    Steve
  • Paapoopa
    January 5, 2006 at 2:05 am
    cool that really helps
    Thanks mate
