Activity › Forums › Avid Media Composer › Error Message
Error Message
Posted by Ken White on April 27, 2009 at 2:17 pmI tried to open an old project and got the following message. File does not contain a valid Avid domain header. What does it mean and how do I fix it?
I am using Avid Xpress Pro 5.8 on a PC with Windows XP SP3.
Ken White replied 17 years, 4 months ago 5 Members · 12 Replies -
Grinner Hester
April 27, 2009 at 6:11 pmwas the project folder renamed, by chance?
It’ll get all fussy if the folders are dinked with in any way. It’s all one tree.
David Braswell
April 27, 2009 at 8:24 pmHave you tried creating a new project, then importing the bins from the old project? That’s a pretty ominous sounding error.
Ken White
April 27, 2009 at 8:31 pmYep, brand new project with the default name “New Project”. Still couldn’t open them. Even tried changing the name of one of the bins and it still wouldn’t open. Thanks,
Ken
Grinner Hester
April 29, 2009 at 3:18 pmIf you hop into your OMFI folder(s) and slowly scroll through, I bet you will find a currupt file… one with a (+) in the file name. Delete it and see if that gets you going. Outside of that, maybe go sifting through your attic for a date or time you could open it before the problem?
Ken White
April 29, 2009 at 3:28 pmGood idea. Hadn’t thought to check the OMFI, or try to open an earlier version of the attic. Thanks!
Ken
Ken White
May 4, 2009 at 5:07 pmWhere would the plus sign be? In front of the file format icon or in front of the file name? Thanks,
Ken
Michael Hancock
May 4, 2009 at 5:16 pmIn front of the filename. For example, if your media file is normally called:
V01.488A3D9F_488A3D488A3D9F.omf
It would looking something like:
+V01.488A3D9F_488A3D488A3D9F.omf
Michael
I’ll be working late. -
Ken White
May 4, 2009 at 5:52 pmMichael —
What does an underline mean, as in
_V01.488A3D9F_488A3D488A3D9F.omf?
Ken
