Activity Forums Boris FX error message
  • error message
    Posted by Dustin Ward on June 16, 2010 at 4:29 pm
    I cannot import my XML into After Effects. I have done this before… I don’t understand.
    I got this message:
    After Effects: AEGP Plugin Boris XML Transfer:
    Cannot import this file with the Final Cut XML Importer.
    Dustin Ward replied 16 years, 2 months ago 1 Member · 1 Reply
  • Dustin Ward
    June 16, 2010 at 4:56 pm
    apparently you have to right click and select “Final Cut XML via Boris XML Trnasfer”. You can’t just drag it in or use command I.
