Activity Forums Adobe After Effects Error Logs Default Path
  • Error Logs Default Path
    Posted by Jozua Judah on August 24, 2015 at 9:50 am
    Hi
    I would like to know if the error log which is created on render could be saved in a different location?
    Regards
    Jozua Judah
    Jozua Judah replied 11 years ago 2 Members · 2 Replies
  • John Cuevas
    August 24, 2015 at 3:12 pm
    You could try searching through the AE preferences file, see if the path info is located there.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jozua Judah
    August 25, 2015 at 6:35 am
    I did check that but there was nothing there, even did a google search on the topic but it revealed nothing, so I thought I would ask on this forum. I am current using After Effects CC 2015.
    Regards
    Jozua
