Activity Forums Adobe After Effects Expressions Error inside try{} statement (script)
  • Error inside try{} statement (script)
    Posted by Ben Rollason on February 12, 2010 at 11:27 am
    Hi there,
    I’m getting a weird error in a script… (not an expression)
    I’m using a try{} catch(error){} statement to test the value of a property that may or may not exist and to avoid a long loop through all properties of all layers testing for its existence.
    However, After Effects is giving me an error at a line inside the try{} statement. “Null is not an object”. The error is not the problem though. The object in question will often be null, that’s exactly why I’m using a try statement, to catch the error when it happens. I’m just a bit perplexed as to why the try statement isn’t catching the error. If I stop the script and run it for a second time, there are no errors and everything works exactly as expected. This happens in CS3 and CS4 and is totally repeatable. Open project -> run script -> error. Run script again -> no error.
    Has anyone else experienced anything similar and / or found a solution?
    Thanks.
    Ben.
    http://www.benrollason.com
    Dan Ebberts
    replied 16 years, 7 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    February 12, 2010 at 3:17 pm
    My experience has been that try/catch doesn’t catch everything, but I don’t think I’ve encountered your situtation where it doesn’t behave the same on subsequent runs. Sounds like it might be a bug.
    Dan
