Activity Forums Adobe After Effects Error in rendering out.
  • Error in rendering out.
    Posted by Vincent . jay on September 21, 2005 at 10:26 am
    Hi
    I was just wondering if there is an inherent problem in afx or it is just that i am doing something wrong. When i render something out, regardless of the output settings, afx seems to put a haze over the top of the footage. I was just wondering if there is a way to remedy this problem, or can suggest something that i may be doing wrong?
    Cheers
    Vincent
    Vincent . jay replied 21 years ago 2 Members · 4 Replies
  • Roland R. kahlenberg
    September 21, 2005 at 3:06 pm
    What are your comp, render, and output settings? Does the comp look ok and the issue is only visible for the rendered movie?
    Cheers
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Vincent . jay
    September 21, 2005 at 3:10 pm
    Yes it just seems a problem when rendering out. However, in the project window, it does look unusually quite grainy. The rendering setting was just Video for windows, no compression. But compared to the original footage there is a white haze created over the top of it for some reason.
    Cheers
    Vincent
    September 21, 2005 at 3:19 pm
    Without looking at the source footage and its properties and not knowing what your comp and render settings are, I really can’t put a finger on the issue.
    Cheers
    Roland Kahlenberg
    broadcastGEMs
  • Vincent . jay
    September 21, 2005 at 3:29 pm
    Hi
    No problem, ill just do a trial and error see if i can locate the problem. Thanks for your help anyway.
    Cheers
    Vincent
