Activity Forums Adobe After Effects error in background rendering per error log… ok?
  • error in background rendering per error log… ok?
    Posted by David Aldridge on January 5, 2014 at 6:28 pm
    The error message in the error log file says
    There is an error in background rendering so switching to foreground rendering after 240 frames completed out of total 300 frames. (26 :: 142)….
    then goes on to say
    After Effects warning: A frame failed to render while using Render Multiple frames simultaneously. Allocating more memory to the background processes in memory and multiprocessing preferences may fix this problem…. then says it finished the composition
    the question is… is the render good? Did AE render the “failed frame” in foreground mode successfully, or did it fail the frame and render the rest of the frames in foreground mode.
    I could re-render, but 5 hours plus… would rather not if possible
    CC complete plan. I7 2600 16g ram SSD GTX 460
    David Aldridge replied 12 years, 8 months ago 3 Members · 4 Replies
  • Todd Kopriva
    January 5, 2014 at 6:44 pm
    Does it look good to you?
    After Effects team blog
  • David Aldridge
    January 5, 2014 at 6:58 pm
    yes – the files appear to preview OK, but it is supposedly just 1 frame and maybe I can’t see it glitch as it goes by… and I don’t want a glitch in the DVD menu transitions to show up later after I have authored in Encore if the glitch freezes during playback or something while playing the final DVD
  • Ridley Walker
    January 5, 2014 at 8:45 pm
    To inspect the render you could import it into After Effects and drop it on the ‘new composition’ icon in the Projects panel.
    Then go to the frame indicated in the error message, using the page up/down keys to move forward and backwards around the suspect frame.
    If it is corrupted then just render out that portion of the comp by restricting the work area and edit the two renders together. That should save you 5+ hours rendering.
  • David Aldridge
    January 5, 2014 at 9:35 pm
    Awesome…. I don’t see any frame errors, I am going to assume the Renders are solid ok. thx.
