Activity › Forums › Adobe Encore DVD › Error importing Assets “OSStatus Error = -37”
  • Error importing Assets “OSStatus Error = -37”
    Posted by David Popper on April 8, 2009 at 1:44 pm
    I’m running CS3 on my Mac Pro with OS 10.5.6 I created several separate program streams in Compressor and have imported them as assets into Encore…except for one. I’ve re-exported multiple times and each time I try to import into Encore, I get the error message: “OSStatus Error = -37”
    Does anyone know what this error message means and/or how to remedy it? I’ve done everything the same as the others but this one doesn’t work. The file size is less than a gig and i have over 100 gig’s available.
    Any ideas?
    David
    Chris Beeman replied 12 years, 3 months ago 5 Members · 5 Replies
  • David Popper
    April 8, 2009 at 6:01 pm
    I’m not sure if this is the problem or not, but I might have figured it out. I renamed to file to make it shorter (thinking that was the problem) still no luck. Then I removed the slash that was in the file name and it seemed to work. apparently Encore doesn’t like symbols in the file names. maybe that’s what error -37 means – invalid filename or something.
    If anyone can confirm or offer a different explanation, that’d be great
  • Jordan Willox
    September 24, 2009 at 9:01 pm
    Totally confirmed. I had a colon in the name of the disc and it stopped building at the same place a bunch of times.
    When I removed the colon… shazam. It worked.
  • Nick Kuprion
    August 22, 2010 at 5:26 am
    yep, it looks like that did the trick!!!
    It’s All About Video…
  • Barold Lynch
    March 30, 2012 at 12:17 pm
    brilliant! I love the internet
  • Chris Beeman
    June 18, 2014 at 3:15 am
    Hi, I’m having the same issue and struggling to fix it..
    how did you rename your assets without compromising your links?
