Activity Forums Apple Final Cut Pro Legacy Error: File Unknown
  • Error: File Unknown
    Posted by Missdivagirl on July 7, 2006 at 11:55 pm
    Every so often when I try to save my project it tells me Error: File Unknown. The only way to save is a new file on a different drive. Has anyone else had this problem and if so, do you know what is causing it?
    Cheers!
    Cheers!
    Missdivagirl replied 20 years, 2 months ago 2 Members · 2 Replies
  • Walter Biscardi
    July 8, 2006 at 12:57 am
    Corrupted preferences can cause this and a lack of RAM can cause this when you have a very large project.
    Walter Biscardi, Jr.
  • Missdivagirl
    July 8, 2006 at 10:52 pm
    Walter,
    The sizes of the projects vary… some are considerably large but also happens to small :30 second spots with only two files imported in.
    I will trash prefs and try that but have done this recently for another problem.
    Thank you!!!
    Angelina
    Cheers!
