Activity Forums Adobe After Effects Expressions Error fallback method(s)
  • Error fallback method(s)
    Posted by Jurgen Koch on September 23, 2020 at 2:00 pm
    My default template uses a ‘master color comp’ with a series of colors,  (ColorControl_01, ColorControl_02, etc)
    Normally a project will start with a series of brand colors, and as it develops, the colors will shift slightly by way of the brand guidelines being updated by the client/agency.
    I’ve been using a system that pulls the desired colors from the color comp with the expression:
    var colorNum = thisLayer.name.split(" ")[0];
    comp("_colorMaster").layer("ColorMaster").effect("ColorControl_"+colorNum)("Color");
    So the layer name determines the color of the fill, IF the first two characters of the layer name are numbers, followed by a space. What I would like to do is create a fallback so that if the layer name does NOT start with two numbers, it will disable the expression, (or render with #00FF33 ??)
    It seems to be an if/than situation, but evaluating the characters seems to be where I am getting stuck.
    Thanks in advance
    Jurgen Koch replied 5 years, 12 months ago 1 Member · 1 Reply
  • Jurgen Koch
    September 23, 2020 at 3:53 pm
    solution from Rob Barrett:
    if (!isNaN(colorNum)) {
    } else {
    [0,255,0,255]
    if the layer name starts with 01, 02, 03, 04, etc it will reference the color in the color master, otherwise, it gives is pure green
