Activity Forums DaVinci Resolve “Error: Failed to save project”
  • “Error: Failed to save project”
    Posted by Rick Turners on October 14, 2011 at 9:24 pm
    When I try to save the project I’m in I am getting this error.
    “Error: Failed to save project __________”
    I have no clue what I could have done to set this off.. I havent installed anything new etc.
    Obviously as I’ve done hours upon hours of work on this I’m a little concerned!
    Rick Turners replied 14 years, 11 months ago 3 Members · 6 Replies
  • Dan Moran
    October 14, 2011 at 9:29 pm
    Hey Rick,
    Can you try doing an Export + of the project?
    You can do this on the Config page by right clicking the project name.
    It exports the whole project with stills etc.. and should help you keep your work if your having any saving issues.
    Hope this helps.
    D
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Rick Turners
    October 14, 2011 at 9:36 pm
    Ok, tested some other projects, its not allowing me to save anything, gives me the same error message.
  • Rick Turners
    October 14, 2011 at 9:38 pm
    It gives me the same error when I try to Export+
  • Rick Turners
    October 15, 2011 at 1:09 am
    Ok,
    I tried to upgrade to 8.1 to see if that would do the trick.
    It said “no database connected” and asked if I wanted to upgrade my database.
    I hit upgrade, and it said this.
    “Failed to upgrade database: Failed to apply patch
    patch_8.0.0.78_8.1.0.110 to database Local_DB: ERROR:
    index “BtPathIngo_SM_Clip_id_idx” contains
    unexpected zero page at block 38
    HINT: Please REINDEX it
    QPSQL: Unable to create query”
  • Vivek Vedagiri
    October 15, 2011 at 1:17 am
    Hi Rick,
    Please read this older thread about a similar problem.
    https://forums.creativecow.net/thread/277/8102
    Could you try to run the commands suggested by Rohit there?
    Vivek Vedagiri
    Blackmagic Design
  • Rick Turners
    October 15, 2011 at 7:18 pm
    That did it 🙂
    Thanks!!
