Activity Forums Adobe After Effects Expressions Error Expression in After Effects
  • Error Expression in After Effects
    Posted by Gabriel Silva on January 18, 2019 at 6:42 pm
    Hello guys. Can you help me? I apologize for the bad english, this is using google translator.
    I am doing a work that I use the following expression for the effect of typewriter in a text layer.
    L = text.sourceText.length;
    T = time * effect (“Speed”) (“Slider”) – effect (“Start At”) (“Slider”) * effect (“Speed”) (“Slider”);
    F = Math.round (time% 1);
    if (F == 1 | (T 0)) {Fl = “|”} else {Fl = “”;}
    substr (0, T) + Fl
    but I need the inserted text to be the same as the name of a composition other than the text.
    can you help me?
    I already tried to use the following expression but it does not work:
    compName = comp (“Business”). name
    Gabriel Silva replied 7 years, 8 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    January 20, 2019 at 8:04 am
    T = time * effect("Speed")("Slider") - effect ("Start At")("Slider") * effect ("Speed")("Slider");
    if (F == 1 | (T == 0)) {Fl = "|"} else {Fl = "";}
    mytext = thisComp.name.toString();
    mytext.substr (0, T) + Fl
    Senior Graphic Designer
  • Gabriel Silva
    January 21, 2019 at 10:29 am
    Oh my God. Finally!! Perfect thank you!
