Activity Forums Adobe After Effects Expressions Error else/if expression
  • Error else/if expression
    Posted by Tepi Kuncoro on July 22, 2024 at 2:57 am
    Hello, I have working on else/if expression in my time remap layer, I’m not sure what’s wrong in my code but I’m sure the wrong is on else/if section:
    fps = 1/ thisComp.frameDuration;
    lt = thisComp.layer("Speed Control").effect("Animation 1")("Menu").value;
    if (lt==1) {
    li=1*fps lo=1*fps
    }else if (lt==2) {
    li=2*fps lo=2*fps}
    }else (lt==3) {
    li=3*fps lo=3*fps
    m1 = 0;
    m2 = framesToTime(li);
    m3 = framesToTime(lt-lo);
    m4 = framesToTime(lt);
    k1 = 0;
    k2 = framesToTime(30);
    k3 = framesToTime(30);
    k4 = framesToTime(0);
    if(time < m2) {
    linear(time, m1, m2, k1, k2);
    } else if(time < m3) {
    linear(time, m2, m3, k2, k2);
    } else {
    linear(time, m3, m4, k2, k2);
    Thank you for your help!
    Brie Clayton replied 2 years, 1 month ago 3 Members · 3 Replies
  • Dan Ebberts
    July 22, 2024 at 6:15 am
    There are some issues, just from a syntax standpoint. This gets rid of the errors, but I don’t if it does what you were hoping for. If not, let us know what it is that you want it to do.
    if (lt==1) {
    li=1*fps;
    lo=1*fps;
    }else if (lt==2) {
    li=2*fps;
    lo=2*fps;
    }else {
    li=3*fps;
    lo=3*fps;
    m1 = 0;
    k1 = 0;
    if(time < m2) {
    } else {
  • Tepi Kuncoro
    July 22, 2024 at 10:45 am
    Thank you so much Dan, it’s works!
  • Brie Clayton
    July 22, 2024 at 1:36 pm
    Thanks for solving this, Dan!
