Activity Forums VEGAS Pro Error during batch render
  • Error during batch render
    Posted by Colin Anderson on March 19, 2012 at 5:22 pm
    Hi all,
    I’m trying to use the batch render script in Sony Vegas. I’ve got a series of regions set up on the timeline. When I run the batch render script, Vegas will render the first region fine but then halts with this error:
    Warning: An error occurred while creating the media file Clip1.m2tsSony AVC-MVC_ 1920×1080-60i.m2ts.
    A device does not exist.
    Details:
    The playback device Microsoft Sound Mapper does not support the current output format.
    The playback device Microsoft Sound Mapper does not exist.
    I click OK and behind it is another error window:
    An error ocured during the execution of the script C:Program FilesSonyVegas Pro 11.0Script MenuBatch Render.cs.
    Exception thrown by method called.
    Details: If the detail is important, I’ll try to grab it next time the error occurs.
    I don’t use the soundcard on this system. I’m using a USB wireless stereo headset for audio playback. I tried all three options for the audio device setting in the Vegas preference: Microsoft Sound Mapper, Direct Sound Surround Mapper and Windows Classic Wave Driver. I get the same error for all three except for the name of the sound mapper.
    Anybody familiar with this problem and know of a solution?
    Thank you.
    Colin Anderson replied 14 years, 6 months ago 3 Members · 5 Replies
  • Jeff Schroeder
    March 19, 2012 at 6:36 pm
    Are there differences between the first and second regions regarding audio tracks? Does the second region use an audio track mapped to a bad device?
    Windows 7 64-bit, ASUS P6X58D, i7 960 3.20GHz, 24.0GB DDR3, 12TB connected storage
  • Colin Anderson
    March 19, 2012 at 7:01 pm
    Not that I can see. The whole timeline has the same project properties. I don’t know how to set audio tracks to different audio devices so whatever that is its been left to default. Besides, after rendering region 1, I deleted region 1 and ran the script again. It rendered region 2 successfully and gave me the same error. Deleted region 2 and ran the script again. It rendered region 3 successfully and gave me the error again and so on and so forth.
  • Jeff Schroeder
    March 20, 2012 at 6:16 am
    Looks like my reply wound up in the either…
    This is probably a script issue. Paste the description of the script here (version, author, etc.)
    Maybe Mike Kujbida can send you a better version. He is one of the best at scripts here.
  • Mike Kujbida
    March 20, 2012 at 10:15 am
    Jeff, I wish I could help but I’m still on Pro 10 and have only used the batch render script that comes with that version of Vegas.
  • Colin Anderson
    March 21, 2012 at 3:35 pm
    I’m using the script that came with Vegas, not a custom script. It appears to be something with my machine. Either a hardware or software issue because I tried it on my other system and it works flawlessly.
    This one got me puzzled.
