Activity Forums VEGAS Pro Error During Batch Render to Avid DNXhD
  • Error During Batch Render to Avid DNXhD
    Posted by Steven Broido on June 20, 2014 at 7:53 pm
    Hi All,
    Having a problem when trying to batch render regions in Sony Vegas 13 into AVID DNxHD.
    Getting the following error message:
    “An error occurred while crating the media file XXXXX[0]. The file name is not valid.”
    Any ideas on a work around or solution?
    Attaching the full error code below…
    Thx!
    Steve
    Here is more info:
    System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.ApplicationException: Render failed:
    file name: C:\Users\XXX\Desktop\XXXXX[0].mov
    Template: AVID DNXHD SAVE 1280
    at EntryPoint.DoRender(RenderArgs args)
    at EntryPoint.DoBatchRender(ArrayList selectedTemplates, String basePath, RenderMode renderMode)
    — End of inner exception stack trace —
    at System.RuntimeMethodHandle._InvokeMethodFast(IRuntimeMethodInfo method, Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeType typeOwner)
    at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
    at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
    at Sony.Vegas.ScriptHost.ScriptManager.Run(Assembly asm, String className, String methodName)
    at Sony.Vegas.ScriptHost.RunScript(Boolean fCompileOnly)
    Aleksey Tarasov replied 12 years, 3 months ago 2 Members · 1 Reply
  • Aleksey Tarasov
    June 21, 2014 at 8:14 am
    – make sure regions do not have illegal characters, if you use region names as the file names,
    and what is XXXXX[0].mov?
