Activity Forums Adobe Premiere Pro Error decompressing – now AME and Premiere freeze
  • Error decompressing – now AME and Premiere freeze
    Posted by Tannie Low on December 7, 2012 at 9:13 pm
    I’ve always had a problem with codecs. But I’m almost to my ends with trying to import this MPEG2 clip:
    I’m running CS6 and have purchased QuickTime Pro 7.6.6
    Here’s my InstalledCodec report: https://www.secularuh.org/hosted/report.html
    My main problem in troubleshooting this issue is that with such a long list in InstalledCodec, I have no clue what could be causing the problem or where to begin.
    The guy who gave it to me compressed it from a 300GB AVI to this file I have now, but I can’t import it! Please help!
    Tannie
    tlow87gmail.com
    MediaInfo:
    General
    Complete name : C:UserstlowDocumentsEnvoyMPV2012_12RAWEnvoy Nov 2012_PGM_0001.mp4
    Format : MPEG-PS
    File size : 19.1 GiB
    Duration : 26mn 26s
    Overall bit rate mode : Variable
    Overall bit rate : 104 Mbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Format settings, GOP : N=1
    Duration : 26mn 26s
    Bit rate mode : Variable
    Bit rate : 100.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 1.609
    Stream size : 18.6 GiB (97%)
    Audio #1
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Duration : 26mn 26s
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Stream size : 72.6 MiB (0%)
    Audio #2
    Format : MPEG Audio
    Duration : 26mn 26s
    Bit rate : 384 Kbps
    Tannie Low replied 13 years, 9 months ago 3 Members · 4 Replies
  • Ann Bens
    December 7, 2012 at 10:18 pm
    Don’t ever install codecs, unless absolute needed.
    When installing Premiere it comes with all the codec you need.
    There are a lot of Roxio codec on your machine.
    I am not sure but I think the problem lies in the bitrate which is 100 mbps. That is very high.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • John-michael Seng-wheeler
    December 8, 2012 at 1:18 am
    As far as I can tell, Premiere doesn’t support rendering to MPEG-2 at resolutions higher then 720×608 except HDV in a quicktime.
    That doesn’t mean it can’t import them, but this could be why your files won’t play.
    Also, this MPEG-2 video is in an mp4 container. I don’t think there’s anything technically wrong with that, but it’s certainly an odd choice by whoever encoded it.
  • Tannie Low
    December 8, 2012 at 3:01 pm
    Yea I accidently renamed to MP4 when trying to fix it, it is originally a MPG file extension.
  • Tannie Low
    December 12, 2012 at 6:07 pm
    After many unsuccessful attempts, Xvid4PSP finally converted it to a working MP4 file.
    https://www.videohelp.com/tools/XviD4PSP
