ERROR crash when Exporting from Edit Suite
Media 100 8.2.2 XR OS 10.3.9
I have a 2 hour program with video & audio music tracks. I try to Export from the Edit Suite as a Program, Export Video, Export Audio, Export Chapter Marks as a Self Contained Movie (Quicktime). I keep getting a window with ERROR and everything locks up. I have to Force Quit and restart the computer.
In watching the progress of the export it looks like the Video is exported OK and then when the Export swithches to Audio, that is when it crashes.
With 2 hours of music from many clips, Is there any way to check to find the bad piece of audio that is causing this lock up? It all sounds and looks fine when viewing from the timeline.
Is there anyway to check the audio to fine the bad section? should I export ausio and video separately? any other settings that might work better?
jerome
