Activity Forums Adobe Premiere Pro error compiling movie message
  • error compiling movie message
    Posted by Butch Mcdonald on January 7, 2008 at 1:20 am
    This is a weird one,
    I have read up on alot of info about this error but no solution suggested has fixed it. I have tried everything and it’s starting to get me down.
    HP XW8000
    XP serv pack2
    Dual xeon 3.06g/hz
    1 gig ram
    I have an array of 1.2 terrabytes for video and a separate internal audio drive i.e. no space problems.
    I have tried to go to a different drive.
    I have restarted numerous times.
    I have opened and renamed new sequences and projects with auto save off etc
    I have tried many different codecs.
    I have no effects/filters on any instances.
    I have spent hours investigating if any files are corrupt.
    In this particular situation I have a 3min 50sec sequence which I am trying to export as an uncompressed QT file.
    While trying to investigate possible corrupt files I started to export smaller sections. I eventually came to a point where I could export the timeline from the start to about 3 min 19sec every time, but as soon as I went over about 5000 frames it always gave me the compiling error yet I could export with no problems the last minute or so, hence no corrupt files.
    Can anyone help me out?
    Cheers
    Butch Mcdonald replied 18 years, 7 months ago 1 Member · 1 Reply
  • Butch Mcdonald
    January 7, 2008 at 5:14 am
    Motherboard just died, so I guess if it was slowly dying it may have had something to do with my probs… will replace and advise… Thanks for reading
    Helping others gives you good cowma.
