Activity Forums Adobe Premiere Pro Error compiling movie
  • Joe O’morang’a
    December 17, 2010 at 8:16 pm
    when u have nothing else left but you have to deliver your project, try the two camera technique one with analogue or s-video in, then connect the i link to camera 1 (can be a simple dv camcorder) to the pc Then connect camera 1 to cam 2 (one with video input) via the analogue cables provided. the just play from premiere and it goes thru the chains of cams and record it on dv tape, though quality will suffer a bit but well… I said earlier that thats when u have no option left.
    Man it saved my ass once.
    if the analogue and rca or s video cables are incompatible, add a tv set with video in and out to the chain and in between the cameras(you know what i mean)
  • Jamie Wonnacott
    May 27, 2011 at 11:10 am
    I experienced this same problem exporting a wedding video timeline as Avid DNxHD and found the following solution:
    If you move the Rendering Dialogue Box (before clearing the error message) you can see which frame the export process stalled. I then navigated in the timeline to this frame and identified the clip affected. Using the Slide tool I shifted the clip a couple of frames to the left (or right). The clip then exported successfully.
    I have no idea why this worked. I didn’t have any gaps, non-iframe video clips or non-wav audio in the timeline.
    Just one of those things I guess? Hope this helps.
    Jamie Wonnacott
    http://www.newvisionmedia.co.uk
    http://www.entwinedfilms.com
  • Jaeson Jrakman
    June 9, 2011 at 5:25 am
    If anyone has found a workable solution to this problem, please let me know in this thread:
    https://forums.creativecow.net/readpost/3/912020
    Thanks in advance!
  • Richard Cohen
    April 1, 2013 at 9:49 pm
    Now before you tease me , I use Premiere Elements 11 and am having error compiling movie prompt.
    I’d love to try shutting off the program monitor. How is this done?
  • Lourdes Borelli
    April 24, 2013 at 11:49 pm
    Hola tengo un problema no me deja importar archivos de audio mas especifico de música los descargue de distintos medio y cuando lo quiero importar me sale “Error en formato de archivo”.Ya probé un montón de cosas y no encuentro solución.
Page 4 of 4
