Activity › Forums › Apple Final Cut Pro Legacy › error code: “not found”
  • error code: “not found”
    Posted by George Bonilla on December 3, 2006 at 3:38 am
    I recently upgraded to TIGER and FCP5. I first tried to import my FCP project (a 2 hour movie) into DVD Studio Pro, but it wouldn’t import. My QT version didn’t either. I tried to export my project with compressor, so I could import it to DVD Studio Pro. It said I did not have enough space on my hard drive and had to cancel it. Now when I open my FCP project and try to render, I get an error code that says “not found”. I’m using a G5 dual.
    Will Salley replied 19 years, 9 months ago 2 Members · 1 Reply
  • Will Salley
    December 3, 2006 at 9:29 pm
    I had the same behaviour with FCP after the crossgrade to 5.1.2. In addition to not being able to export using Compressor, I also had a “corrupted” sequence that displayed the same “not found” error code. Unfortunately, I was not able to find a known reason, but I was able to complete the project by trashing the FCP cache and preference files. I also made copies of the last known working file in the FCP autosave vault and used that after trashing the caches, etc.
    After the project was completed, I re-installed FCP and DVDSP and have had no reoccurrences.
    System Info – G5/Dual 2 – 10.4.8 – QT v7.1.3 – 8GB ram – Radeon 9800Pro – External SATA Raid – Decklink Extreme – Wacom 6×8
