Activity Forums Apple Final Cut Pro Error Code -36 when copying FCPX libraries
  • Error Code -36 when copying FCPX libraries
    Posted by David Decker on August 14, 2015 at 4:56 pm
    Hello,
    I have been having a fairly regular issue trying to backup daily and final library files from video projects. I am backing up and archiving libraries (with media consolidated) from my main external LaCie thunderbolt drive to external usb 3 drives. I also have an OWC Thunderbolt 2 dock in the chain. The projects all play through and I have “shared” versions of the project for different outputs (Vimeo, Youtube, movie files etc) successfully. Then, trying to copy the library to an external drive for backup and archiving often results in an (Error code -36) message “because some of the data in “project” can’t be read or written”.
    I was able to back these up using ShotputPro5 (a file copy utility application) – but seems I should not have to purchase products to do this within the OS.
    FCPX 10.2.1
    OSX 10.10.4
    MBP 2.2 GHz (Early 2011)
    8 GG ram
    LaCie thunderbolt media drive (reformatted prior to last project backup issue)
    Seagate external usb drives for backup and archive
    OWC Thunderbolt 2 drive dock
    New library to receive Error Code -36 – 50 Gb in size
    Ugh!
    Dave Decker
    Jeremy Garchow replied 10 years, 9 months ago 3 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    August 14, 2015 at 6:10 pm
    Are all the drives formatted as HFS+?
  • David Decker
    August 14, 2015 at 6:29 pm
    Hi Jeremy,
    Yes, all drives are Mac OS extended (HFS+). I back up projects to two separate external usb 3 drives – a primary backup and a secondary backup (in case one drive fails). Same error -36 happening. Primary media drive also freshly formatted for latest project with same result.
    Just purchased ShotPutPro5 and am currently running same backup which failed within MacOS.
    Media files seem fine – I can play them within the folder, and also within the project. Final project timelines export (share) just fine. Issue is with copying. Wondering if it’s a hardware issue, or if it’s something in the FCPX files.
    Been doing some research and have not found others posting about this issue….
    Dave
    David Decker
  • Jeremy Garchow
    August 14, 2015 at 6:31 pm
    Be sure to ignore all ownership of files on the external drives.
    It would be good to quit everything, boot in to Recovery Mode and repair disk permissions on your boot drive.
    I think this might be a permissions error.
    Jeremy
  • David Decker
    August 14, 2015 at 6:36 pm
    Thanks Jeremy,
    I will try this. I did replace my internal drive with an SSD drive about 6 months ago. I do regularly repair permissions – but not in Recovery mode.
    Thanks – I will report back.
    Dave
    David Decker
  • Bill Davis
    August 14, 2015 at 7:58 pm
    On my new MacBook Pro’s SSD I’ve been having mild permissions issues with file copying as well. I sometimes have to copy to a connected hard drive cuz the internal SSD won’t let a file land. Let us know if you find out anything. I was going to try and tackle the whole permissions thing after this project gets to a resting state.
    Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
  • David Decker
    August 14, 2015 at 8:36 pm
    OK, restarted in recovery mode and repaired permissions on SSD boot drive.
    Restarted computer, and tried to copy same FCPX library file from same LaCie thunderbolt drive to external usb 3 backup drive, and still got the Error Code -36.
    FWIW, prior to repairing the permissions as stated above, I tried copying the same FCPX library file to and from the same drives using ShotPutPro5 (which I just purchased) – and it worked fine. Weird! ShotPutPro is promoted as a camera card transfer app to copy and verify files to multiple drives at once – but also does whole hard drives, and single FCPX library files too! Also will text you when process is done.
    Wish I could do this in MacOS though…..
    So far, I am thinking it is not a hardware issue.
    Dave
  • Jeremy Garchow
    August 14, 2015 at 8:41 pm
    [David Decker] “I will try this. I did replace my internal drive with an SSD drive about 6 months ago.”
    Was it a clean install or restored from a backup?
  • David Decker
    August 15, 2015 at 12:08 am
    Hi Jeremy,
    Yes, it was a clean install.
    David Decker
  • Jeremy Garchow
    August 15, 2015 at 12:32 am
    I find the thing that trips up transfers like this the most, is errant alias files in the library.
    If you dive in to the library package and find any alias files and delete them, it may help.
  • David Decker
    August 15, 2015 at 1:36 am
    Thanks, I will try that too. It baffles me though that a file copy utility app (like ShotPutPro5) can make the copy, to multiple drives with verification, and the same process hiccups in the MacOS….
    FWIW, there are some aliases in this particular project – and I also have other very clean library files with straight footage, one event and one project with chapter marks which is shot and edited the next day, which choke on backup too. ????
    David Decker
