Activity Forums Adobe Encore DVD Error code 3 when I do a Blu-Ray
  • Error code 3 when I do a Blu-Ray
    Posted by Franco Cionini on August 17, 2018 at 8:50 am
    Hi everybody!
    I have an issue with encore dvd I can’t manage to make a blu-ray. Everytime an error message appears (code 3 file can not open – with the directory of a video) and burns the blu-ray, so I can’t get all the video in it. I have tried to delete the videos causing a problem and upload a new version of them. Nothing seems to work and I just keep wasting blu-rays.
    Any suggestions?
    Thank you very much!
    Franco Cionini replied 8 years ago 2 Members · 5 Replies
  • Jan Janowski
    September 2, 2018 at 1:40 am
    I have seen that error occasionally, writing to a BR Disc…. Enough to be frustrating..
    I got around it by exporting a BR Image (ISO File)… and then burning the BR from ISO, which doesn’t error out…
    Actually, this kills 2 birds with one stone… I usually make an ISO file as a backup after Disc is approved, Deleting all files involved, and Just keep the ISO…
    Jan
  • Franco Cionini
    September 2, 2018 at 9:54 am
    NICE! it worked perfectly!!
    Man you gave me some hope, I was about to give up on that.
    I’ll just do this way until I figure something.
    Thank you!
    Cheers
  • Jan Janowski
    September 2, 2018 at 10:41 am
    Happy to help!!
    Jan
  • Jan Janowski
    September 2, 2018 at 10:48 am
    Happy to help!!
    One other thing I’ve found…. If you are used to using both BD-RE and BD-R media… You’ll have to Save an ISO for each media….
    It’s not as if you save an ISO and then select media later…. No…
    A separate ISO with pre-selected media has to be made for each media….
    I ususally Write to RE media until it gets approved, then switch to -R media…
    After approval of BD-R media, and dubs are made from ISO, I then delete or archive all footage except ISO…
    Frees up space for next project!
    Jan
  • Franco Cionini
    September 2, 2018 at 3:45 pm
    Thank you for that! I’ll give it a try and compare.
    I’ll let you know!
    Thanks Again! Cheers
