Activity Forums Boris FX Particle Illusion Error code 00000005
  • Error code 00000005
    Posted by Newbie0221 on July 7, 2006 at 5:34 pm
    I have just installed Particle Illusion 3.0.1 and have been receiving a message “Error Code: 00000005” that prevents the program from even starting up. Has anyone encountered this problem and if so, what did you do to correct this. I appreciate all help in advance, thank you.
    Derek Davis replied 18 years, 1 month ago 4 Members · 4 Replies
  • Alan Lorence
    July 7, 2006 at 5:47 pm
    Probably means you don’t have a C: drive. Email wondertouch support for more help.
    Alan.
    wondertouch
  • Superal
    September 13, 2006 at 9:44 am
    Same problem, and I definately have a C: drive!
    Was there a solution for this?
  • Alan Lorence
    September 13, 2006 at 12:36 pm
    In order to allow non-administrator users to run particleIllusion 3 on
    Windows XP, log in using an Administrator account, then run the attached bat
    file. This should modify the license file to allow all users to access it.
    Just unzip it, and double-click it.
    https://www.wondertouch.com/downloads/pi3_user_access.zip
    Alan.
    wondertouch
  • Derek Davis
    July 25, 2008 at 12:11 am
    Hi there. I am having the same problem and tried the patch but it’s still not working. “Error code 00000005” still pops up and the program won’t start. Please help!
