Activity › Forums › Boris FX Particle Illusion › Error Code 00000005 on Application Startup
  • Error Code 00000005 on Application Startup
    Posted by Superal on September 13, 2006 at 9:39 am
    Hi Guys,
    My design guy gets Error Code 00000005 on Application startup when he is logged in as himself. However it works fine when opened under the administrator login, where we installed the app.
    Please Help!
    thanks
    Superal replied 20 years ago 2 Members · 2 Replies
  • Alan Lorence
    September 13, 2006 at 12:38 pm
    In order to allow non-administrator users to run particleIllusion 3 on
    Windows XP, log in using an Administrator account, then run the attached bat
    file. This should modify the license file to allow all users to access it.
    Just unzip it, and double-click it.
    https://www.wondertouch.com/downloads/pi3_user_access.zip
    Alan.
    wondertouch
  • Superal
    September 14, 2006 at 9:05 am
    Perfect, that patch worked. how do you come up with these patches?
    Thanks for your help.
