Activity Forums Blackmagic Design Error Capturing with Premiere Pro
  • Error Capturing with Premiere Pro
    Posted by Norman Lafranchi on August 8, 2005 at 11:26 pm
    I just installed my new Decklink Extreme board, and I’m having problems capturing using the 5.1 drivers. When I try to capture from a Beta SP deck (or any deck) I get the following error:
    [\dev\CaptainDoby\Backend\Src\Time\Timecode.cpp-1266]
    It generates this error when you hit “stop” after capturing. It seems to capture fine with no dropped frames but then this error message comes up when you try to stop capture. The error message occurs in the Decklink DV or Decklink YUV 8 bit modes.
    I’m running an AMD Athlon 3500+ system with an ASUS Mobo (A8N-SLI Premium).
    The install went fine. Everything seems to be working normally other than this very strange error.
    Any ideas would be appreciated.
    Norman Lafranchi replied 21 years, 1 month ago 3 Members · 5 Replies
  • Luke Maslen
    August 9, 2005 at 12:10 am
    Hi Norman,
    Please perform a capture in Blackmagic Deck Control rather than Premiere Pro. Use the Preferences in Deck Control to select an 8-bit NTSC or PAL easy setup. Then perform your capture. Do any errors or error messages occur using Deck Control or does the problem appear to be confined to Premiere Pro? This test will help verify that your machine is capable of capturing uncompressed video.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Andrew Mcleod
    August 9, 2005 at 2:30 am
    Hi Norman
    Please as well as the testing mentioned above can ensure that you are using the latest Decklink Driver 5.1.
    https://www.blackmagic-design.com/downloads/software/DeckLink_Windows_v5.1.zip
    Andrew McLeod
    Black Magic Design
  • Norman Lafranchi
    August 9, 2005 at 3:44 am
    HiLuke
    I did a test capture using the deck control software and it worked fine. Furthermore, I imported the clip into a Premiere job and it played without difficulty.
  • Norman Lafranchi
    August 9, 2005 at 6:57 pm
    I have the latest software for sure… v 5.1, the capture problem seems to be limited to adobe premiere.
  • Norman Lafranchi
    August 9, 2005 at 8:06 pm
    I was trying to capture by playing the deck and then pressing record… and scene detect seems to be on by default. By marking in and out points I was able to capture my footage.
    Can scene detect be turned off when capturing in a Decklink job? It seems to be greyed out.
