Activity Forums Avid Media Composer Error =???
  • Error =???
    Posted by Chip Hess on September 9, 2016 at 9:44 pm
    MC 8.4.2
    Mac OS 10.9.5
    iMac 27″ 32GB RAM
    Working with 1080p H264 29.97 material
    I AMA link and transcode to DNX145
    I have gotten the same format material on this project previously, all was fine.
    Last 2 files that came in are throwing the attached error in playback.
    Timeline starts stuttering, dropping frames, then will go black,
    then the error message.
    This is getting pretty frustrating, as the same files play in Premiere just fine.
    Ideas?
    Chip Hess replied 10 years ago 2 Members · 2 Replies
  • John Pale
    September 10, 2016 at 2:28 am
    Since you apparently have Adobe Creative Suite…then use Adobe Media Encoder to transcode to DNX HD MXF OP1a. Then, back in Avid, manually select the MXF AMA plugin and CONSOLIDATE (not transcode).
    Avid can be finicky about the file when linking. Sometimes its just a bad frame at the end of the file. If it works with Adobe, just use that and move on. You can pull all your hair out trying to debug it, otherwise.
  • Chip Hess
    September 10, 2016 at 9:21 pm
    Direct importing fixed it.
    First time for everything, I guess…
