Activity Forums Adobe After Effects Error AE CS3 – After Effects error: AE_OpenGL: Failed to generate shadow map (5065::0)
  • Error AE CS3 – After Effects error: AE_OpenGL: Failed to generate shadow map (5065::0)
    Posted by Darin Miyashiro on January 28, 2008 at 5:29 pm
    Hi, I got this error when using AE CS3.
    I have a ATI RADEON X1300 Pro – graphics adapter – Radeon X1300 Pro – 256 MB.
    I had 3 layers, 1 solid, 1 text and 1 spotlight.
    I wanted to have the light shine on the text and cast
    a shadow on the solid layer.
    Then I got the error: AE_OpenGL: Failed to generate shadow map (5065::0).
    Do you know what could be the problem?
    System:
    Dell XPS 410, windows xp-pro
    RAM: 4gigs
    How do I find out what version of OpenGL i’m using?
    Praveen Kumar replied 15 years, 5 months ago 4 Members · 6 Replies
  • Steve Roberts
    January 28, 2008 at 6:11 pm
    Did you try switching off OpenGL in AE?
    Most pros turn it off — it’s not that well-implemented to be useful.
  • Darin Miyashiro
    January 28, 2008 at 6:16 pm
    How do you turn off OPEN GL in AE CS3?
  • Steve Roberts
    January 28, 2008 at 7:03 pm
    Preferences>previews?
  • Darin Miyashiro
    January 28, 2008 at 7:35 pm
    Thanks, I’ll test it when I get home.
    I hope it works!
    Thanks for you help, I really appreciate it!
    Darin
  • Munendra Kumar
    August 29, 2010 at 5:05 pm
    thnx it works ……
  • Praveen Kumar
    March 23, 2011 at 3:34 pm
    Thank U Mr.Steve Roberts. It worked well
