Activity Forums Apple OS X Error (-9972) Help please!
  • Error (-9972) Help please!
    Posted by Christopher Kinsman on April 5, 2007 at 5:34 am
    Working on G4 867 OS 10.3.9 During “Package” from Indesign it froze up. Couldn’t use force quit – had to use “power button” shutdown. Upon restart, an internal data drive (not HD) the computer was accessing at the time of freeze now comes up “A volume you’ve inserted can’t be read by OSX” with the choices initialize – ignore – dismount. With Disk Utility i see the name for the volume has now changed and is greyed out. I can click on the drive and receive the following error Catalog file entry not found for extent the volume needs to be repaired volume check failed : The underlying task reported failure on exit (-9972)(when in verify or repair attempts). What’s the best way to fix this. Disk Warrior 4? Data Rescue II? Or is there something else in OSX that can help. Thanks in advance for your time and knowledge. Kind Regards, Chris K.
    Christopher Kinsman replied 19 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
