Activity Forums Adobe After Effects Error 86 :: 1 when importing large jpg to After Effects
  • Error 86 :: 1 when importing large jpg to After Effects
    Posted by Corrie Parks on January 24, 2019 at 7:14 pm
    Am getting an error when trying to load a hig-res jpg into After Effects.
    Error 86::1
    Then I get an error that the file is corrupt or damaged
    I can open the jpgs in PS and Photo viewer
    Files vary a bit in size but the one I used for testing is 21941×16360 (all are RGB 8-bit)
    If I save the file as a png from PS it will import. But if I use SAVE AS to create a new jpg, then it will not, UNLESS I reduce the image size to 18500px width. Then it’s happy. (I tried lots of incremental decreases in size until I found one that works.)
    New 185000 jpg is 150MB, but the png that works at full res is 371MB.
    I can import other jpgs from this scanner, but on closer look I think they are all under 18500px wide.
    I have to do a long animated zoom into 100% in a 4K comp, hence the gigantic dimensions of the scans.
    I would prefer not to convert all these scans to png files as I have over 30 and it takes roughly 5min to save each giant file. But mostly I’m curious as to why AE doesn’t like a jpg that size. Adobe says it will accept up to 30,000×30,000 images.
    AE 2019 16.0.1
    Windows 10
    cleared my caches and have 57.7GB RAM allocated for AE
    Walter Soyka replied 7 years, 7 months ago 2 Members · 1 Reply
