Activity Forums Adobe Premiere Pro error 1605 – PPro CS4 installation error
  • error 1605 – PPro CS4 installation error
    Posted by Aske Jørgensen on July 5, 2010 at 8:02 am
    Hi guys
    I have had CS4 installed for quite some time now, but recently I decided to upgrade to CS5. Because of this I uninstalled my CS4 MasterCollection installation in order for the new CS5 installation to work properly. Unfortunately, After Effects and Premiere Pro CS5 do not support 32-bit I found out. Therefore I uninstalled the entire CS5 suite and started installing CS4 once again – but with no luck so far.
    The installation just aborts and I get an error message saying “one or more components was not installed correctly.”
    When I click “more information on the problem” it is displayed that the problem is due to “Error 1605 – This action is only valid for products that are currently installed.”
    I’ve tried to clean everything up with windows cleanup, but I still can’t figure it out.
    I’m running Vista by the way 🙁
    Please help 🙂
    Regards,
    /Aske
    Vince Becquiot replied 16 years, 2 months ago 2 Members · 2 Replies
  • Aske Jørgensen
    July 5, 2010 at 2:02 pm
    UPDATE: I now tried to use the CS5 cleaner tool in order to remove all previous installed components, but still no luck.
    However, the error message now says: “Error 1603. Fatal error during installation”
    I still don’t know what to do to avoid this problem!?
  • Vince Becquiot
    July 6, 2010 at 1:49 am
    Please see this post:
    https://forums.creativecow.net/thread/3/904166
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
