Activity › Forums › Avid Media Composer › error
error
Posted by Core Van der hoeven on August 9, 2011 at 8:31 pmI just upgraded from FCP to the MC
all went great, just a few hick ups
when I leave the application I get the message: “Segmentation fault” in thread “MainThread”, at address 0x0
does anyone wat that means
and when I try to convert a QT prores fire with sorenson squeeze the application terminates after 2 minutes or so
Any help is welcome
thanks, CoreCore Van der hoeven replied 15 years, 1 month ago 5 Members · 11 Replies -
Shane Ross
August 9, 2011 at 9:49 pmWhat version of Avid MC? What is your OS and QT versions? Avid is VERY picky about operating system and Quicktime versions it works with.
Shane
Read my blog, Little Frog in High Def -
Core Van der hoeven
August 9, 2011 at 10:01 pmIt’s the MC 5.5.2 and the latest up grade from snow leopard and the latest QT version
thanks for the reply
Core -
Shane Ross
August 9, 2011 at 10:13 pmTry uninstalling Avid, then reinstalling. It’s fairly simple.
Unless someone else knows the issue right away. I don’t…sorry. That’s just what I’d do.
Shane
Core Van der hoeven
August 9, 2011 at 10:18 pmthanks,
I do that right away tomorrow maybe it helps
Core -
John Pale
August 9, 2011 at 11:24 pmBefore you go through the trouble of a re-install, try repairing permissions on your boot drive using Disk Utility.
Sounds like Avid is having trouble writing data when you quit the program. Could be a permissions problem.
Won’t hurt anything to try and only takes a few minutes.
Kris Anderson
August 10, 2011 at 8:50 amI get it all the time. System is completely AVID qualified. It means MC doesn’t have enough RAM to exit so it force quits at the last minute. Don’t know why as I have 16gb of RAM in the Mac, but it doesn’t affect anything else. Often happens while Magic Bullet is still open during exit.
Core Van der hoeven
August 10, 2011 at 9:03 amI try to repair permissions
It happens also by me with the magic bullet(looks) I have 12GB ram
Core -
Daniel Frome
August 10, 2011 at 11:55 am5.5.2 is not certified to run on the latest SL (10.6.8). I believe that version is only 10.6.6 certified.
5.5.2.1 was recently certified to run 10.6.7.
10.6.8 changed many things in the openGL code which caused compatibility issues for aja, adobe, and avid (among others).
I’m not promising anything, but 10.6.8 is likely your issue. I’ve read in the Avid forums that a 5.5.3 update needs to happen in order to officially support 10.6.8 and Lion.
Core Van der hoeven
August 10, 2011 at 12:48 pmI had to look it up the QT version have is 10.0
it seems that QT doesn’t updates with the regular software update
Core -
Kris Anderson
August 10, 2011 at 9:50 pmTry quitting MB Looks before quitting Avid… On my Mac it stays open in the dock even after MC has quit. I think that’s usually the trigger.
