Activity Forums Apple Final Cut Pro Legacy ‘error -1309’ trying to copy file to MS/DOS drive—HEELLPPP!
  • ‘error -1309’ trying to copy file to MS/DOS drive—HEELLPPP!
    Posted by Phillip Powell on June 14, 2007 at 6:11 am
    Trying to deliver a .avi from edited show to a client so they can load on to their server for play back. Hopefully not the problem except been trying to get it to them for the last 2 days and cannot get this to work. MUST have for them by 7am tomorrow…and no closer to resolving this.
    Here’s the deal—formatted a 160 gig FW 400 drive (disc utilty) MS/DOS, then trying to copy my output (I dumped it out of FC 5.1.4 to one of my drives) .avi to the MS/DOS drive and it gets thru about 20 of the 28 min. it says it needs and throws a ‘error -1309’ (‘file’s EOF, offset, mark or size is too big’, whatever that helpful bit of info means ) and stops.
    Now it copied smaller files 2-3 gig no problem. But the full show which is 41 gig’s won’t go. TRied 3 other external dives and cases all MS/DOS, reformated and same thing.
    Going to see if I can just do the output straight to the DOS drive instead of copying, but jezusonabike, I’ve done this pleanty before. And the output/encode takes about 4-5 hrs for the 17min HD show of course.
    Didn’t think there was a limit on Win/DOS file sizes, but any thoughts appriciated.
    DP G5 2.5 GHz, 3 Gig RAM, OS 10.4.8 FCP 5.1.4
    Thanks in advance.
    p2
    David Roth weiss replied 19 years, 2 months ago 4 Members · 6 Replies
  • 13 Create COW Profile Image
    13
    June 14, 2007 at 6:17 am
    That drive format cannot hold files that are larger then 2GB some of your files are larger.
    You must ether split the video files, give them a mac formated drive or format the drive NTFS on a windows computer and copy the files over a network.
    MS/DOS aka Fat32 is a VARY old format back when it was created the thought of having a file that was larger then 2GB was imaginable.
  • Colin Mcquillan
    June 14, 2007 at 6:20 am
    I believe the individual file size limit on fat32 is 4gig.
    Colin McQuillan
    Vancouver BC
  • David Roth weiss
    June 14, 2007 at 6:53 am
    Your only solution at this late hour is to deliver to them on a drive formated for MAC and tell the client they will need to load MACDrive on their computer in order to mount the drive and load yur file to their server.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
    13
    June 14, 2007 at 6:56 am
    [Colin McQ] “I believe the individual file size limit on fat32 is 4gig.”
    yes you are correct
    its been a long day and I was a little distracted because I finally have the chance to upgrade to FCS 2
  • Phillip Powell
    June 14, 2007 at 7:07 am
    Thank you kind sir. That, I will do.
    Do appriciate it.
    p2
  • David Roth weiss
    June 14, 2007 at 7:15 am
    No problem!!! And, it does work, I use it here to do exactly what you need.
