Activity Forums Adobe After Effects Error (0::42) at startup. . . crash
  • Error (0::42) at startup. . . crash
    Posted by Blacky on December 21, 2005 at 10:35 am
    Good morning everybody 🙂
    Yesternight I wanted to start AEX (6.5.1), and it crashed immediately with an error message (0::42). I’ve searched here already, can’t find any helpful info.
    I updated to the latest NVIDIA graphic drivers, i’ve got XP PRO SP2… I’ve tried to repair AEX, didn’t do anything.
    Now as next i’ll reinstall it and try other stupid different things, but I just want to know if this problem has a specific known solution, or if it’s a BillGates-like guess-where-the-problem-is thingy…
    tia
    cheers,
    blacky
    Vikram Rao replied 15 years, 9 months ago 3 Members · 4 Replies
  • Blacky
    December 21, 2005 at 11:28 am
    btw, here a screenshot:
  • Blacky
    December 22, 2005 at 3:42 pm
    SOLUTION: because i just remember that I had that a few month ago after a full re-install, here’s the solution to the 0::42 error:
    just get rid of any DIVX install. Or uninstall a DIVX version, test if AEX works then. Here all is fine now. I know that some have no probs with having Divx installed and running AEX, but well, on mine it doesn’t work, and the solution is: uninstall DIVX.
    cheers 🙂
  • Hawkmankt
    December 30, 2005 at 7:57 pm
    I hope that’s what it is for me. I realize that I did install Roxio Easy Media Creator (which has a divx portion) after I last had AEX working. Now AEX doesn’t work. I’m uninstalling Roxio right now.
    I’ll cross my fingers and I’ll let you know.
    A good way to threaten somebody is to light a stick of dynamite. Then you call the guy and hold the burning fuse up to the phone. “Hear that?” you say. “That’s dynamite, baby.” – Jack Handey
  • Vikram Rao
    December 16, 2010 at 8:21 pm
    i had the same problem try this:
    1. Uninstall Quicktime player
    2.Test it..it will open and chose “Once per session” and go
    3.If it fails disable Opengl ,or update u r drivers to latest
    4.I hope it works.
    -Vikram
    hackersunited.hpage.com
