Activity › Forums › Panasonic Cameras › Erratic Audio Delay
  • Erratic Audio Delay
    Posted by Stphanie Holtz on September 10, 2008 at 8:40 pm
    The problem I’m having is an erratic Audio Delay when I play the footage in a Final Cut timeline that I have shot in 720p 24p with a P2 card. It plays back perfectly on the (HVX-200)camera. And the problem only happens when shooting in 24p; there isn’t a problem when I shoot 720p 24pn or other formats.
    Moving the audio track to sinc up the video, will only match for a few seconds, and it will go out of sinc again.
    I’ve done the easy setup for the project. I’ve also changed the sequence in different ways, and nothing works
    I don’t know if the issue has to do with the camera setup or the set up in final cut.. Any help will be greatly appreciated
    Stphanie Holtz replied 18 years ago 3 Members · 4 Replies
  • Richard Harrington
    September 11, 2008 at 5:30 am
    Make sure your hard drives are RAID drives and fast enough connection for data rate
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Stphanie Holtz
    September 11, 2008 at 6:37 am
    That’s a good thought, but it’s not the problem. Thanks though. The hard drives I’m using are fast enough to handle video. I’m still stumped…..
  • Chris Wright
    September 14, 2008 at 7:35 pm
    23.976 fps in timeline the true framerate, not 24.
  • Stphanie Holtz
    September 18, 2008 at 8:44 pm
    Nope. I’ve tried that, and it still doesn’t fix the problem. I appreciate your help though.
