Activity › Forums › Apple Final Cut Pro Legacy › Erasing clips from FCP
Posted by Karl Bergvall on June 28, 2013 at 9:30 amIs there a way to erase the clips from FCP without having to go to the finder ?
Rafael Amador replied 13 years, 2 months ago 3 Members · 5 Replies -
Rafael Amador
June 28, 2013 at 3:04 pmYou mean erase a clip from your computer from inside FC?
No. Thanks God is a “no destructive” application.
The only change you can do to a clip from inside FC is on the TC.
rafael -
Shane Ross
June 28, 2013 at 5:40 pmActually…yes. Highlight the clips in the Browser, go to the MODIFY menu and choose MAKE OFFLINE, or press SHIFT-D. You’ll be presented with options. Choose the one you want.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Rafael Amador
June 29, 2013 at 3:12 am[Shane Ross] “Actually…yes. Highlight the clips in the Browser, go to the MODIFY menu and choose MAKE OFFLINE, or press SHIFT-D. You’ll be presented with options. Choose the one you want.”
Hi Shane,
Will that erase the clip from the HD?
rafael -
Shane Ross
June 29, 2013 at 9:26 amIf you choose that option. You are presented with three options. Just to unlink the clip from the media file, to move the file to the trash and unlink, or to delete the file from the drive.
Shane
Little Frog Post
Rafael Amador
June 29, 2013 at 11:15 amThanks for the info, Shane.
The truth is that I’ve never explored the “modify” options.
rafael
