Activity Forums Adobe After Effects Eraser Tool
  • Eraser Tool
    Posted by Ola Sanda on November 9, 2014 at 5:24 pm
    Hi there 🙂
    When I erase in a layer, using the eraser tool, the erased area is active in all the frames.
    I have moving objects in the layer and I therefor want to erase areas frame by frame.
    In the Effects Panel “Effects/Paint/Compositing Options/ Effect Opacity” I can keyframe it from 100% to 0%, and do this for every erasing, frame by frame, but it takes a lot of time.
    I’m pretty sure, there must be an easier way, so that the erased area only is active ONE frame and then I erase again next frame etc. etc. Can someone please assist ?
    Needless to say I’m brand new to AE 😉
    Ola
    Ola Sanda replied 11 years, 10 months ago 3 Members · 8 Replies
  • 8 Replies
  • Roland R. kahlenberg
    November 10, 2014 at 7:31 am
    When the Eraser (or any Paint Tool) is selected, the Duration pop-up menu allows you to select the duration of each stroke that you input. Select the option that best meets your needs.
    HTH
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Ola Sanda
    November 10, 2014 at 4:46 pm
    Thanks a lot Roland ! 🙂
    Ola
  • Walter Soyka
    November 10, 2014 at 5:31 pm
    You can also see and modify the extents and durations of paint strokes by selecting a layer in the timeline and revealing the contents of Effects > Paint, or by using the shortcut PP (select a layer and quickly press the P key twice to reveal its paint strokes).
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Ola Sanda
    November 11, 2014 at 12:23 am
    Thanks Walter ! 🙂
    When I go into this contents of Effects > Paint, how can I then see, which painting or erasing belongs to which frame ? For example, if I am in the timeline on a specific frame and I need some adjustings to my erasing on this exact frame, then how do I know which of all the listed erasings (in my case 150), is the one that belongs to my specific frame ?
    Ola
  • Ola Sanda
    November 11, 2014 at 12:32 am
    Thanks Dave 🙂
    In my specific case, I have rotoscoped a persons arm and then later I see, that the rotoscoping could have been better. So I wanted to fx. zoom in to the fingers and make some adjustings with the eraser.
    I guess, that it is possible to go into the effects control and adjust a specific rotoscoped area in a specific frame, but I don’t know how to do that yet 😉
    And also, is it possible to use the Pen Tool for erasing ? When I try to do this, I make a mask but then I don’t know if I can somewhat “erase” that selected are.
    Thanks for helping 🙂
    Ola
  • Ola Sanda
    November 11, 2014 at 5:30 pm
    Hi Dave and thanks.
    I guess this is the same as with the erasings I mentioned, I mean where You go into the Effects < Paint and choose the exact paint listed and then correct it ? Is it the same way You correct rotoscoping ?
    The problem is I still don’t know how to find out, which of all the listed erasings/rotoscopings (in my case MANY), is the one that belongs to my specific frame ? And furthermore how to correct these.
    Ola
  • Walter Soyka
    November 11, 2014 at 5:37 pm
    Using the Paint tool is not a good workflow for roto. It will be a ton of work and almost certainly lead to bad results (chattering edges).
    Start here:
    https://helpx.adobe.com/after-effects/using/animating-shape-paths-masks.html#rotoscoping_introduction_and_resources
    An oldie but goodie:
    https://library.creativecow.net/articles/oconnell_pete/roto.php
    Also consider the Rotobrush tool, which helps automate rotoscoping (but which isn’t perfectly intuitive and will require you to read up a bit):
    https://helpx.adobe.com/after-effects/using/roto-brush-refine-edge.html
    Walter Soyka
  • Ola Sanda
    November 11, 2014 at 8:12 pm
    Thanks for the links Walter, I will definitely look into them.
    And thanks also for Your comments Dave.
    I have rotoscoped what I wanted, but now afterwards I see, that in some particular frames, it could have been better. Therefor I was looking at the Eraser tool. I still don’t know how to make changes to the rotoscoped frame afterwards, so I’ll look at those links now and see if I get it 🙂
    Ola
