Activity Forums VEGAS Pro Erase Tapes?
  • Erase Tapes?
    Posted by Mike Minske on September 15, 2005 at 11:09 pm
    I have a lot of old material on tape (recorded once) that I will probably not need so rather than buy new tape I was thinking of backing up material to them or recording over them. Do you think there will be much of a quality issue recording over the old material or should I buy a tape (electric-magnetic)eraser device and then use the erased tapes to record on? Any suggestions about what make or model of eraser to buy? Thanks in advance.
    Daniel Thornton replied 21 years ago 5 Members · 8 Replies
  • 8 Replies
  • Gary Kleiner
    September 15, 2005 at 11:25 pm
    If they are for your personal use, you have nothing to gain by bulk erasing.
    Gary
  • John Hartney
    September 16, 2005 at 12:41 am
    What kind of tapes are they??
    John Hartney
    werks.tv
    Elgin, Illinois – Chicago area
    847.608.1357
  • Mike Minske
    September 16, 2005 at 1:12 am
    Maxell xr-metal Digital 8 and maxell mini dv. Gary, are you saying it’s worth bulk erasing for non-personal use?
  • John Hartney
    September 16, 2005 at 3:23 am
    Those are metal evaporate tapes and don’t hold up nearly as well as metal particle, which are used in dvcpro line, beta sp, 3/4inch, MII, etc…
    dv tape holds a very strong signal and running it through a demagnitizer doesn’t work.
    If you want to erase all the previous material, I’d suggest stripping it with black and no audio.
    John Hartney
    werks.tv
    847.608.1357
  • Gary Kleiner
    September 16, 2005 at 5:30 am
    [Mike Minske] “Gary, are you saying it’s worth bulk erasing for non-personal use?”
    Only if you need to make sure that the footage that was recorded over doesn’t peek through.
    Gary
  • Stephen Mann
    September 16, 2005 at 6:30 am
    “Peek through”?
    Do you mean “print through” as when an old image shows up in an analog tape playback?
    It doesn’t happen in digital recordings because the next time you record data, it replaces whatever was there before.
    Steve
  • Gary Kleiner
    September 16, 2005 at 6:35 am
    Mostly I am referring to the secondary recording being shorter than the first, however there can be an occasional tape glitch where the previous recording is not totally overwritten.
    Gary
  • Daniel Thornton
    September 16, 2005 at 2:36 pm
    I have not had good success rerecording on DV tapes. Sometimes it will work and other times the previous picture shows through. This might be ok for video taping the family dog but when you need to capture the best picture with no glitches use new tapes.
