Activity Forums Adobe After Effects erase or mask layer in comp
  • erase or mask layer in comp
    Posted by Maxim Moisseev on November 23, 2008 at 6:12 pm
    Hi all!
    I have a comp of two layers in AE CS3: video and a slideshow on the wall.
    In the video footage we have a bus moving in foreground.
    So, how do I manage to erase parts of the slideshow that supposed to be behind the moving bus?
    I know I can create a mask with motion, but in this case it’ll be very difficult.
    “Erase” tool works on a layer view only, but I need to see them both when painting.
    Maxim Moisseev replied 17 years, 10 months ago 2 Members · 2 Replies
  • Darby Edelen
    November 23, 2008 at 8:50 pm
    [Maxim Moisseev] “”Erase” tool works on a layer view only, but I need to see them both when painting.”
    Rotoscoping with the mask tool would be my first suggestion. This could potentially be as easy as creating one rough mask on a separate layer for the bus when it first starts to obscure the slideshow, then motion tracking the bus and applying the data to that layer. Then use this layer as an alpha inverted track matte for the slideshow footage. However, you will probably need to tweak the mask after you’ve done this.
    If you don’t want to deal with that then you could duplicate the video footage layer, paint in the bus frame by frame, then enable the ‘on transparent’ switch and use this layer as an alpha inverted track matte for the slideshow footage.
    Darby Edelen
  • Maxim Moisseev
    November 23, 2008 at 10:29 pm
    Thanks, Darby. Track matte was exactly what I was looking for.
