Activity › Forums › Adobe Premiere Pro › Equivalent to Avid’s “focus” command?
  • Equivalent to Avid’s “focus” command?
    Posted by Kell Smith on March 20, 2018 at 12:44 pm
    Does Premiere have a similar command to toggle focus in the timeline at the playhead, with a one-stroke keyboard shortcut? I’m sure they do, just can’t seem to find it Thanks
    Kell Smith replied 8 years, 6 months ago 2 Members · 2 Replies
  • Todd Perchert
    March 20, 2018 at 3:01 pm
    I usually just use the plus (+) and minus (-) keys to zoom in and out of the timeline at the CTI – not the Plus and Minus on the numeric keypad. Also Forward Slash (\) to show entire sequence.
    TC
  • Kell Smith
    March 20, 2018 at 6:22 pm
    Thank you Todd. I use that a lot too. It would be nice if they had a command that would zoom way in with one keystroke but maybe they don’t. Ok then I’ll make it work. =)
    Drives me nuts that you have to zoom way in to the transition to select it and the cursor is constantly changing to a trim cursor, and you can’t select it. I think I remember reading that this got better in versions after CS6, not sure.
    But a focus shortcut is all-around useful for everything.
