Activity Forums Adobe After Effects Expressions Equally Spread Layers
  • Nino Kapetanovic
    November 5, 2012 at 4:47 pm
    You could access the layers ‘index’ value, its the number right next to each of the layers. So your expression could be something that is like original position + index * YourOffset. Your offset could be a slider you animate over time. So if yourOffset was 10, it would increment all your layers by 10, etc.
  • Scott Skaja
    November 6, 2012 at 2:26 pm
    Just learning expressions, so go gentle on me.
    If you would, please tell me more about index values.
    Scott Skaja
    edit/design/animation
    http://www.scottskaja.com
