Activity › Forums › Apple Final Cut Pro Legacy › Equally spaced clip gaps after duplication
Posted by Rachel Pandza on August 27, 2009 at 5:18 amAfter I duplicated an entire sequence in final cut pro, it had equally spaced gaps between all the clips, they hadn’t changed there were just gaps between every clip, I am using final cut pro 6.0.0, with a g5, with 3.5gigs memory. How do I correct this?, anyone had the same issue?
Nick Meyers replied 17 years ago 3 Members · 4 Replies -
David Roth weiss
August 27, 2009 at 5:30 amFCP 6.0.0 has significant bugs. When it was first released, like 2.5 years ago, Apple released patches for it almost immediately. I would suggest you update ASAP.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Rachel Pandza
August 27, 2009 at 5:35 amI am working on a pretty significant project and I am afraid upgrading made create compatibility issues, as i am a few days from a dadline and want to avoid extra problems. i know it has a ton of bugs but is there anything I can do without upgrading
David Roth weiss
August 29, 2009 at 1:15 pm[rachel pandza] “i know it has a ton of bugs but is there anything I can do without upgrading
“It’s not upgrading that you should be concerned about in this case Rachel.
And, you can always clone your system drive before upgrading if it does concern you. Search around this forum for cloning, you’ll see many posts about how to do it.
David Roth Weiss
Director/Editor
Nick Meyers
August 30, 2009 at 4:41 amyeah, get out of 6.0.0.
as for the spaces:
check the settings of the sequence you pasted into.
sounds like it has a different frame rate than the one you copied from.nick
