Activity Forums Adobe After Effects Expressions Equalizer effect
  • Posted by Dotan Stern on September 19, 2009 at 9:11 am
    Hi
    i have this 5X5 squares
    which each square change its color from black to white
    i want to create an equalizer effect of the squares which means
    some are black and some are white going up in a row
    i guess some expression will work here maybe valueAtTime but that will work one way and then i have to go back to original start how i reverse it?
    anyway what is the best way to build it?
    separating each row from bottom to top? (in a precomp)
    separating each row from left to tight? (in a precomp)
    or maybe each square by itself
    thanx in advance
    Dotan Stern replied 16 years, 12 months ago 2 Members · 6 Replies
  • Filip Vandueren
    September 19, 2009 at 9:45 am
    Can’t you do the effect with the spectrum analyzer plugin + mosaic and grid filters ?
    Your question is very unclear.
  • Dotan Stern
    September 19, 2009 at 12:36 pm
    Ill try to explain better
    i have a comp lets call it square
    in comp i have a 50X50 pixles black square that change to white
    in the main comp i have a 5 squares in each row and 5 in each colmn
    meanning i have 25 squares
    i want to have a look of an equalizser bars rising in different ways
    so i can have only the 5 on the left showing black and the one next to it just 2 are blacks and the rest are white after few frames the third row is black and the others are white
    in reality i have each square showing a video of someone showing a card to the camera making it all black and then remove it
    (its like the effect of people holding cards in a game with letters)
    and i use time remapping to control what is showing
    is that clear?
    thanx
  • Dotan Stern
    September 19, 2009 at 5:52 pm
    Hei filip can you send me your email adress ill send you an example
    thanx
  • Filip Vandueren
    September 20, 2009 at 7:21 pm
    I think I understand it.
    I would create a precomp of the colums (5 vertical squares) where with timeremapping you have the bottom square go from black to white in 1 second, in the next second, you let the 2nd square go white etc.
    You’ll have a precomp of 0 to 5 seconds.
    Now get some audio values with the audio to keyframes,
    and use an expression on the timeremapping of the entire column-precomp so when the audio is quiet, you get time=0 when it is at it’s loudest you get time=5.
    You’ll need different copies of the audio (with audiofilters Low, Mid, High) so every column moves differently. Or if you have Trapcode Soundkeys that makes it very easy
  • Dotan Stern
    September 21, 2009 at 9:36 am
    What expression i need to use in the timremapping?
  • Dotan Stern
    September 26, 2009 at 2:15 pm
    So whats the right expression i have to use
    is it just time-index or something?
    thanx
