Activity Forums Apple Final Cut Pro Legacy Equal interval trimming
  • Equal interval trimming
    Posted by Chad Mcclymonds on November 10, 2011 at 8:13 am
    Hey there, sorry if this has been asked before:
    I have one giant video clip that I am trying to chop up into many clips that are all the exact same size. Is there a way to simultaneously trim the big clip in equal intervals, or do I need to manually scroll along the clip and trim it one point at a time?
    I hope this question makes sense.
    Chad
    Chad Mcclymonds replied 14 years, 10 months ago 2 Members · 2 Replies
  • Andrew Rendell
    November 10, 2011 at 11:37 am
    (Apart from having no idea why anyone would want to do this) I can’t think of a “standard” way of doing it in FCP’s toolset, but there are ways you could go about it, so as a first suggestion:
    make a new layer; load something inconsequential into the viewer (e.g., text); set the duration of the clip to whatever you want your length to be; edit it into the new layer as many times as you need (so you have a continuous series of clips all at the same duration with cuts); select the blade tool and check that snapping is on; run along the vision layer you want to divide up and click as the cursor jumps to each snapping point.
    I expect that someone will have a better way of doing this.
  • Chad Mcclymonds
    November 10, 2011 at 3:07 pm
    Thanks. Yeah, it is a strange need. I’m working with someone on a project trying to match random clips all over the place. I’ve never dealt with it myself.
    But I suppose your method is the best way to go ahead with it for now.
    Thanks again!
