Activity Forums Adobe After Effects equal incraments on motion path
  • equal incraments on motion path
    Posted by Garyjames on May 21, 2006 at 12:42 pm
    Hi All
    I’m using AE version7 and i’m having trouble making equal incraments on motion path so that my graphic/camera look smooth when i play back. I have a tutorial for version 6 which explained there is a twirl feature under position that brings up a graph on the time line and all you do is uncheck smoe boxes that are under the keyframes. I cannot find this function in version7, can anyone help?
    Gary
    Tim Kurkoski replied 20 years, 3 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    May 22, 2006 at 9:05 pm
    What you’re looking for is the Roving Keyframes option. Or sometimes called “Rove in Time”. Look up “roving” in the help, and you’ll find the complete answer. The short answer from my memory says you should right-click on all your keyframes, choose Keyframe Interpretation, and check the rove option.
