  • Colin Mcquillan
    March 21, 2008 at 5:27 pm
    https://www.prepressure.com/library/file-formats/eps
    Colin McQuillan
    Vancouver BC
    Octo 3.2, 8gig, 8800GT, 2×23″ ACD, 2TB G-Speed eS, Kona LHe….
    MBP 2.4, 4gig , 2xLacie Quadra 500gig….
  • Colin Mcquillan
    March 21, 2008 at 5:36 pm
    You’ll have to convert the EPS files to either a tiff, targa, jpeg, or other FCP compatible format. I use photoshop. You’ll also need to define the pixel perimeter, photoshop should ask you to define this when you open. Use either the full frame dimension of your project (eg: 720×48(6) for SD-NTSC with non-square pixel,) or 2X, 3X, so on.., if you plan on doing any pan/scan/zoom of the images.
    Colin McQuillan
    Vancouver BC
