Activity Forums Adobe After Effects EPS file not showing correctly?
  • EPS file not showing correctly?
    Posted by Olly Lawer on April 8, 2012 at 10:47 am
    I’ve brought an EPS file from iStock. They are illustrations with a reflection. Unfortunately, upon import into either AE or Photoshop, the reflection now just shows as a white image. Not a good look. The file is also just one file (there are 12 images). I’ve tried importing as EPS sequence, just as a comp and pretty much any other option I could think of, but the results are the same.
    How do I overcome this problem?
    Olly Lawer
    Tim Vaughan replied 14 years, 5 months ago 2 Members · 5 Replies
  • Tim Vaughan
    April 8, 2012 at 1:56 pm
    Did you try opening the eps in Illustrator? From what it sounds like (and I’m guessing), the image might need to be relinked within Illustrator and saved. Hope this helps
    Tim
    Tim
    Apple XRAID, XServe, MacPro, Macbook Pro, XSAN, FCP Studio (7), AVID Media Composer
    Apple Monitors, Flanders Scientific Broadcast, Panasonic AG-AF100
    Adobe Production Premium, Maxon Cinema 4d
    Beer fridge fully loaded.
  • Olly Lawer
    April 8, 2012 at 2:10 pm
    I don’t have illustrator unfortunately 🙁
    Olly Lawer
  • Tim Vaughan
    April 8, 2012 at 2:26 pm
    I’d contact iStock and see if they can help. Or, if you want to send it my way I can take a look and see if I can relink. tim@7amedia.com
    Tim
    Tim
  • Olly Lawer
    April 8, 2012 at 2:29 pm
    That’s very kind.
    I’ve masked each picture and used the change to color effect to achieve what I want. A but messy, but job done.
    Thanks again!
    Olly Lawer
  • Tim Vaughan
    April 8, 2012 at 2:34 pm
    Very cool, good luck!
    Tim
