Activity › Forums › Adobe Illustrator › EPS COLOUR CHANGE
  • EPS COLOUR CHANGE
    Posted by Roger Burton on January 26, 2006 at 6:00 pm
    Hi all i’ve also posted this on the After Effects forum but had little luck … maybe one of you gurus could help…. I’ve just brought an eps (RGB) into AE (don’t know where it originated) and AE has changed the color quite dramatically so I then opened the eps in pshop converted it to a psd and saved it and the colour looked a little better …. certainly the color values matched what they were in pshop … but just to double check I opened it in Illustrator and the RGB readings are different …. can anyone tell me where this change is happening ie what I see colour wise in Illustrator I’d like to see on Pshop and AE and I don’t think I’ve changed any profiles …. thanks for your time … Roger
    Roger Burton replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
