Activity Forums Adobe Premiere Pro EPK type clips – Format/Codec Questions?
  • EPK type clips – Format/Codec Questions?
    Posted by Jude Poyer on April 23, 2012 at 7:33 pm
    I’m using CS 5.5 on a PC. I have quite a bit of “behind the scenes” footage from shoots I’ve worked on. They vary from Canon DSLR, Sanyo Xacti (mp4), HDV etc. In the past, footage I’ve shot has been used (sparingly) in DVD special features, documentaries etc. I’m sure you have seen similair non-pro footage used like that before.
    I would like to trim some of this footage (cutting out any boring or embarassing stuff)and keep it on a hard drive for editors to use in the future.In the days of miniDV it was easy – I created DV avi files – and could be confident an editor could use them.
    What should I output from PPro, confident that an editor using Mac/Pc FinalCut/Avid etc will be able to use them in HD projects? I’d like good quality, but not massive file sizes. If I was on Mac it’d be Prores 422, I guess. But I’m on PC.
    I asked on another forum, and someone suggested Avid DNxHD – I can’t seem to output those. Cineform seems a good quality/size compromise…but don’t editors need to download that codec?
    Suggestions are much appreciated.
    Jude Poyer replied 14 years, 4 months ago 2 Members · 4 Replies
  • Tero Ahlfors
    April 23, 2012 at 7:40 pm
    Avid DNxHD is a quicktime codec so choose Quicktime as the format and Avid DNxHD for the codec.
  • Jude Poyer
    April 23, 2012 at 7:51 pm
    Thanks for replying. When I choose QT, the only options are varieties of NTSC or PAL DV.
  • Tero Ahlfors
    April 23, 2012 at 7:55 pm
    Don’t choose a preset. Choose the codec from the video codec drop menu in the video tab.
  • Jude Poyer
    April 23, 2012 at 8:47 pm
    Thanks – I never knew about that! I plan to match resolution to sources, but what settings are advisable for:
    Resolution (120 8-bit, 36 8-bit)?
    Color levels (RGB or 709)?
    Depth (24, 36, 48, 64 bit)?
    Audio – is AAC a good choice?
    Thanks Again.
