Activity Forums Compression Techniques Episode Pro vs Bitvice?
  • Episode Pro vs Bitvice?
    Posted by Luke Cline on October 23, 2010 at 1:04 pm
    I’m about to do a lot of encoding of MPEG-2 files to run on BrightSign HD210 media players. This is for a media installation, and the displays are all 1080p LCD monitors. I’ve tested Compressor and Squeeze, now looking for (hopefully better) alternatives and looking at Episode Pro and Bitvice. Can anyone sway me one way or the other? I’ve run demos of both and am still unable to make a final decision of which one to purchase. Thanks very much.
    Craig Seeman replied 15 years, 11 months ago 3 Members · 4 Replies
  • Luke Cline
    October 23, 2010 at 3:56 pm
    Update to my post and what I’m CURRENTLY using, per Craig Seeman’s recs on how to get fastest compression help…
    * Computer – Mac
    * Operating system – OSX 10.6.4
    * Software used – Compressor 3.5.3 and/or Squeeze 6.0.2.41
    * Source codec – Pro Res 422
    * Destination codec – MPEG2 transport stream
    * Type of destination use – BrightSign HD210 media player
  • Rich Rubasch
    October 23, 2010 at 6:22 pm
    For HD MPEG2 I’m not sure compressor isn’t enough. Also it seems that the BrightSign HD210 has a maximum 25mbit playback so be sure to account for audio if you have it. But HD transport streams at high bitrates should look great out of compressor.
    At low SD bitrates (like 3mbps or less) you get a better encode with BitVice, but for HD videos especially coming from a codec like ProRes they should look great.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Luke Cline
    October 25, 2010 at 3:47 pm
    Rich, thanks. So you think Bitvice does a better job of SD encodes? Very interesting.
  • Craig Seeman
    October 26, 2010 at 8:36 pm
    Episode 6 has improved MPEG2 encoding over Episode 5 as it now uses MainConcept for MPEG2 (as well as MPEG1 and H.264). You really need to compare with Episode 6 and not Episode 5.
